Posted Tue, 29 May 2018 20:39:58 GMT by Jose Luis Montiel Consultor TI
Hola buenas tardes.
Nuestro cliente contrato DocuWare Cloud y le esta apareciendo el siguiente mensaje:
login token expired
por lo que se en la nube esta parte no se configura, Por que se esta presentando este error?
Saludos
https://www.docuware.com/sites/default/files/forums-images/Captura_2.PNG
Posted Wed, 30 May 2018 07:26:14 GMT by Simon H. Hellmann Wedderhoff IT GmbH Systemadministrator
Hello Jose,
the "Login Token expired" Error usually appears when the Client was idle for too long.
Reloading DocuWare with F5 and performing the action again should fix this problem.
