Posted Tue, 15 Jun 2021 08:46:56 GMT by Gilles TATON
Hi there,
I would like to format my date to input it in file name.
I try that :
Put my date in Global Text Variable : GV__DATE
and then try to format it like that, in another indexes that give my filename : GV_CDPF + "_" + GV_NATURE__DOC +  "_" + Format(GV_DATE__DOC,"dd/MM/yyyy")
The result : 12345_Invoice_dd/mm/yyy
I don't know where i'am wrong..
Thanks !!
Posted Thu, 17 Jun 2021 15:22:39 GMT by Gilles TATON
Hello all,
So, for the moment i have split my actual index into 3 text variable like that :
Put the date indexe in text variable, and then split it like that :
Year variable : Split(GV_DATE__DOC, "/")(2)
Month variable : Split(GV_DATE__DOC, "/")(0)
Day variable : Split(GV_DATE__DOC, "/")(1)
Then compose your date like you want :
GV_Day__Txt+"/"+GV_Month__Txt+"/"+GV_Year__Txt
Thanks.
Posted Tue, 29 Jul 2025 07:22:38 GMT by Support Docuworx
a
Posted Mon, 04 Aug 2025 22:35:59 GMT by Jacob Eaton Software Integration Specialist
Hey,
I see you have a solution for this, but I wanted to let you know that you can get the result you want without having to split.
All you need to do is use the Format(DW_DOCUMENT_DATE, "dd/MM/yyyy") or DW_DOCUMENT_DATE.ToString("dd/MM/yyyy") when you assign to the GV_DOC__DATE global variable. Also, this is assuming that you have an index field that is a Date or DateTime type.
The issue is that the format function is different for a Text variable than it is for a Date or DateTime variable.
Regards,
Jacob Eaton
