Posted Mon, 01 Oct 2018 09:53:35 GMT by Savio Karimaruthumkal
With DocuWare 7, the administrator no longer has access to the new document trays created automatically when you add a new user. Is this by design? I am pretty this was not the case with the older versions.
Savio
Posted Mon, 01 Oct 2018 10:25:40 GMT by Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Savio,
I am sure this is by design.
Posted Wed, 10 Oct 2018 12:36:04 GMT by Savio Karimaruthumkal
Hi Phil
Thanks for getting back to me.
If you want to setup intelligent indexing for these newly created document trays, how would you go about doing that?
Savio
Posted Wed, 10 Oct 2018 12:46:32 GMT by Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Savio,
From DocuWare 6.11 onward, Intelligent Indexing is defined against a file Cabinet Store Dialog, not a Tray. Therefore, you define Intellix accordingly, and then instruct the user to attach their tray to the dialog you specify. While doing that they can also add the DocuWare administrator to the tray if required. This is a security measure.
Posted Thu, 11 Oct 2018 11:53:56 GMT by Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Savio,
we are aware of that and with the next version the user who creates a user will get automatically access to the created tray as administrator.
Posted Thu, 11 Oct 2018 15:54:00 GMT by Jon Weston File IT Solutions Sr Application Developer and RIM specialist
Good to hear, Tobias.  What about trays that are automatically created by a user synchronization workflow? Will the administrator automatically have access to those in the next version as well?
Posted Wed, 24 Oct 2018 07:12:58 GMT by Savio Karimaruthumkal
Thanks Tobias.
Posted Fri, 02 Nov 2018 14:44:29 GMT by Tobias Getz DocuWare GmbH Team Leader Product Management
Yes, this also works for user synchronization.
