Posted Thu, 02 Aug 2018 14:16:14 GMT by Craig Heintz SE
I have set up a field to use a select list and check the box for "The user can only use entries from the list to set field"
The select list has Yes and No as choices
When storing, this field allows for it to be left blank, Yes, No as storable entires.
How can I stop an empty entry from being allowed?
Posted Thu, 02 Aug 2018 14:47:20 GMT by Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Craig,
Make the field mandatory. That will stop it from being stored empty.
Posted Thu, 02 Aug 2018 15:32:58 GMT by Craig Heintz SE
Thank you.  Checking the REQUIRED box for the Database Field has done the trick.
