Posted Wed, 28 Mar 2018 14:45:41 GMT by Casey Miller Director of Technical Services
What is the Free Query box looking for? I would like to only pull up document in a result list that have the document type as "Payroll Change". The field in MSSQL is Document_Type
What query command would it be looking for here?
https://www.docuware.com/sites/default/files/forums-images/dwurlcreator.png
Posted Wed, 28 Mar 2018 15:14:00 GMT by Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Casey,
It is looking for a WHERE clause, without the word WHERE. Same syntax as used in dialogs, filters etc.
DOCUMENT_TYPE = "Payroll Change"
For example.
Posted Wed, 28 Mar 2018 15:17:21 GMT by Gilles Sauvagnat Altexence
Hi
Answer to your question here, I hope so -:)
Gilles
Posted Wed, 28 Mar 2018 15:25:00 GMT by Joe Kaufman Bell Laboratories Inc No longer there
One more (hopefully helpful) response on this... Here is the comment section of the Foxpro subroutine I wrote to run free queries via URL integration. Covers some of the experiences I have had doing integration queries:
REMEMBER! Field names in queries are case sensitive! Field names (in the database) are usually ALL CAPS. The actual database field name of a field can be viewed in the DocuWare Administration desktop application. Queries place field name in square brackets and the value on double-quotes. Though, for numeric fields,  the quotes appear to be optional. Operators can have whitespace around them. Here are example query expressions:
[DWDOCID]=123                                       && Query by the internal document ID.
[CUST_NO] = "WA60"                               && Query field "CUST_NO" to exactly match "WA60".
[LASTNAME] LIKE "K*"                             && Wildcard search.
[SHIPTO_STATE] = EMPTY()                   && Query SHIPTO_STATE for empty values.
[BILLTO_STATE] = NOTEMPTY()             && Query BILLTO_STATE for non-empty values.
[DocuWareFulltext] = "find this string"       && Full-text search.
[DWSTOREDATETIME] > 2017-06-14 19:45:31              && Date/time expression.
[START_DATE] >= 2016-06-01 AND [START_DATE] <= 2016-08-01    && Boolean conditional.
Expressions can be joined by AND or OR and can be qualified with NOT. Delimiters around string values MUST be double-quotes. Also, the conditional statements and compound keywords (e.g. LIKE, AND, OR, etc.) need to be capitalized as well. If multiple documents are found, a result list is displayed in the browser. If only one document matches the search, it is directly displayed.
*** SPECIAL NOTE WHEN USING DATE/TIME FIELDS ***  Date/time fields are stored in DocuWare as UTC timestamps. While queries in the web client or Platform SDK allow the use of local date/time formats, URL Integration queries appear to use the date/times passed in as-is and compare against the stored UTC timestamps. So, if you are using date/time fields in your query, the date/time values need to be converted to UTC to get accurate results.
Posted Wed, 28 Mar 2018 15:49:46 GMT by Casey Miller Director of Technical Services
Thank you! This worked perfect. [DOCUMENT_TYPE]="Payroll Change"
