Publié Tue, 30 Oct 2018 19:06:53 GMT par Nicolas Grondona Tecnico
Hi, i wanted to insert data in an external DB from docuware , is it that possible ?. If it is possible how will be the way to do it ?
Publié Wed, 31 Oct 2018 05:30:53 GMT par Andreas Ruttkamp
I think "Autoindex" is what you are searching for. You can read data from an external DB to fill index fields in docuware AND you can manipulate fields in external DB ...
