Publié Fri, 31 Aug 2018 10:19:06 GMT par Casey Miller Director of Technical Services
has this feature been removed with DocuWare 7?
Publié Fri, 31 Aug 2018 12:01:51 GMT par Simon H. Hellmann Wedderhoff IT GmbH Systemadministrator
Hello Casey,
no, the feature still exists. This right is controlled via function profiles. However, you can also assign it to a single User.
To do so, open the Web-Configuration. Navigate to "User Management" and click the User who needs the right. Next, Select "Function profiles" and scroll down a bit. There is a checkbox called "Assign functions directly" - check this one. Now, when you scroll down further, you should be able to assign the right "Edit select lists" to this user.
Publié Fri, 31 Aug 2018 18:56:29 GMT par Casey Miller Director of Technical Services
This worked! Thanks, Simon!
