Publié Mon, 22 Jan 2018 20:00:10 GMT par Jason .
In Notifications, is there a way to send a reminder notification every 48 hours after the first notification is sent.  I can create a workflow with the same criteria as the notification, and run that workflow every 48 hours, making it "modify" some value to initiate the notification again (notification rerun on modification).  This is a tedious workaround. Is there an easier way?
Publié Mon, 22 Jan 2018 22:06:41 GMT par Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
There is no solution for what you wish to do. Notifications are triggered on an event, not on a cycle. If a workflow is not suitable then I would suggest a customized SDK program to do what you require.
