Publié Tue, 26 Nov 2024 19:36:19 GMT par Edward Clarke Community Service Partners Director of Information Technology
Is there any guides on how to configure the workflow module for invoice processing.  I've seen some videos but they are just more "this is what you can do".  I would like to be able to apply GL Coding to the invoices and also match up PO's to invoices for automatic approval.
Publié Wed, 27 Nov 2024 09:25:21 GMT par Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Edward Clarke,
are you a customer or a partner? If you are a customer, I suggest speaking to your partner about a personalized training using your process as an example.
If you are a partner, you should get the DSC training or ask someone in your company who already did that for help, as this also uses invoice processing as an example.
All the functionality is documented in the Knowledge Center, Knowledge base and Partner Portal, but learning how to use that best is something you have to do for yourself or with the help of your DW Partner/DW Academy/DW Professional Services.
