Registrato Thu, 28 May 2020 18:29:31 GMT di Rick Hetherington DIrector
Can anyone tell me the upgrade path from 4.5b to 6.7?
If it incudes Version 5, is there any link to download a copy ?
Thanks in advance.
R
Registrato Wed, 03 Jun 2020 13:43:06 GMT di Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Rick,
4.5b to 6.7 is a pretty big step. As far as I know, you need to go at least to 5.1c. This is basically a separate installation with a migration of data as the architecture of the whole system was changed.
Here is the system requirements for version 5.1c.
I would not recommend to do this change by yourself, please involve you DocuWare partner and maybe even DocuWare support. They can also provide you with the needed versions.
Then you need to upgrade to 6.7, the system requirements are here.
Director Product
Registrato Wed, 03 Jun 2020 17:44:18 GMT di Rick Hetherington DIrector
Thank you for your reply, it's much appreciated.
  I do have some experience with this conversion as I did it for my production system some time ago.
This is for file cabinets that were acquired as the result of a merger. The former company never upgraded.  I managed to update to 5.1b now, but I no longer have my copies of 5.1b sp3 and 5.1c.  Would it be possible to provide a link?
Thanks advance.
Sincerely,
RH
Registrato Thu, 04 Jun 2020 08:14:47 GMT di Tobias Getz DocuWare GmbH Team Leader Product Management
Support should be able to help you with the links. Just create a support request.
Director Product
