Registrato Mon, 23 Jul 2018 17:27:52 GMT di Seth Jaco Support Specialist
We have had one of our clients receive the cloud update to 7.0. I tried remoting into the Admin console and it is not allowing me to log in. For the address I have tried clientname.docuware.cloud and port 9000 and that did not work. I then tried the old docuware-online.com with port 9000 and it tells me that I have an incorrect version. Just wondering what I am missing.
Seth
Registrato Mon, 23 Jul 2018 17:40:32 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Seth,
In the drop down list for Authentication method, select : Desktop Apps Authentication.
Registrato Mon, 23 Jul 2018 17:56:46 GMT di Seth Jaco Support Specialist
I have tried that, while the connection was active in the Desktop Apps, and it states "Cannot find active authentication server. All servers are either stopped of the communication channel settings don't allow a connection.
Registrato Mon, 23 Jul 2018 18:09:49 GMT di Josef Zayats
Seth,
just a silly thought. But Docuware Administration-online needs to be updated to V7.
Registrato Mon, 23 Jul 2018 18:28:07 GMT di Seth Jaco Support Specialist
It is, I ran the update this morning after I received the confirmation that they had been moved over to the latest version.
https://www.docuware.com/sites/default/files/forums-images/DWAdmin.JPG
Registrato Mon, 23 Jul 2018 18:33:03 GMT di Steve Shriver Application Specialist
I'm having the same issue with a cloud customer that has not been upgrade to 7 yet.
Registrato Tue, 24 Jul 2018 06:18:44 GMT di Simon H. Hellmann Wedderhoff IT GmbH Systemadministrator
Hello Seth,
try to use <companyname>.admin.docuware.cloud as server with port 9000. This should work.
Registrato Wed, 25 Jul 2018 17:27:50 GMT di Seth Jaco Support Specialist
Strange thing, when I run that as the address I get the error about incorrect version, however, now when I select Desktop Apps Authentication it works. Who knows what happens but it appears to be working fine now. Thanks for the help everyone.
