Registrato Fri, 16 Mar 2018 13:53:58 GMT di Casey Miller Director of Technical Services
Not sure this is possible without having the Enterprise Server License.
Registrato Fri, 16 Mar 2018 14:01:59 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
A DocuWare Professional Server License allow you to install the DocuWare Services on one machine only.
A DocuWare Enterprise license will allow you to install the DocuWare Services on two machines.
Therefore, to install DocuWare on 4 different servers, will require the customer to purchase 4 Enterprise Servers.
Simply installing a single Professional Server license on 4 machines would be a breach of the licensing agreement, and the servers will not be able to communicate with each other.
I suggest that you take the discussion up with your Regional Sales Director.
