Registrato Tue, 26 Jun 2018 12:55:42 GMT di Scott Steele Ricoh USA
So if I have a database field set as "Required" a message appears [Please fill all mandatory fields] when saving from a dialog if you do not have a value set for the "Required" field.
If within the user > settings > viewer > viewer = "Open DocuWare Viewer with index dialog in new window" is set, when you update a record from a result dialog and omit (leave the field empty), select save, there is no message [Please fill all mandatory fields]. The viewer window simply closes and disregards any metadata changes.
Is this by design or just an oversite?
Registrato Tue, 26 Jun 2018 13:06:03 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Scott,
That is a software fault in 6.12. It has been fixed for DocuWare 7.0.
