Registrato Tue, 13 Mar 2018 15:36:55 GMT di Steve Shriver Application Specialist
I want to create a Task list in a v6.12 DW cloud system that shows every document except those that contain the word 'Complete'. Examples are 'Engineering Complete', 'Billing Complete', 'Shipping Complete', etc. There is no "Does not contain" option so I am using the Is(where clause) option. I have tried "NOT *Complete* and NOT LIKE %Complete% , with and without quotes,to no avail.
Does anyone have the correct syntax handy?
All clues appreciated,
Registrato Tue, 13 Mar 2018 16:58:53 GMT di Tim Ohm
I think check your quotes, NOT should be outside, otherwise it would be looking for NOT in in the index value.  NOT LIKE "*COMPLETE"   might do it...
Registrato Tue, 13 Mar 2018 18:05:51 GMT di Steve Shriver Application Specialist
In MySQL Query Browser this works; WHERE STATUS LIKE '%complete'
In DW this does not; LIKE '%complete'
nor does this; LIKE "*complete"
or this; LIKE "complete"
or this; LIKE 'complete'
As always, any clues appreciated
Registrato Tue, 13 Mar 2018 19:23:28 GMT di Josef Zayats
Steve, I think that using whre (like clause) with the value set just as  NOT *Complete*
No Quotes just NOT in all caps and to astericks around the word you want to exclude.
This should work
Registrato Tue, 13 Mar 2018 19:43:59 GMT di Steve Shriver Application Specialist
Thanks Josef. You are, of course, correct. Thanks again.
Registrato Tue, 13 Mar 2018 22:33:23 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Everyone,
Search syntax in DocuWare has changed very little since the days of the Windows Client. Search help  has always been available in the Admin tool, and is available at help.docuware.com.
http://help.docuware.com/en/#b57855t51009n75755
Phil
