Registrato Mon, 11 Jun 2018 12:27:02 GMT di Gabriele Guerra
I have a question. If I have a file cabinet that contains 100 documents, all the documents have the same metadata.
I need to restrict the access only for 1 file in a way that only one defined user can read it.
How can I accomplish it?
Gab
Registrato Mon, 11 Jun 2018 16:39:26 GMT di Casey Miller Director of Technical Services
Just create a field and call it say "Visible" Then the documents you want  only that person to see add them to that filter profile. you can create a FC profile called visible and then not visible. You can also hide the field in certain dialogs so it looks like it isn't there.
