Registrato Mon, 28 Jan 2019 18:07:48 GMT di Steve Shriver Application Specialist
Way back when there used to be a separator page that we could print and make copies of. You could then insert one of the separators at each place in a stack of pages whwere you wanted a new document to start. When scanned in using the old windows client, DW would create separate documents in the document tray and discard the separator page image. It was a great way to handle bulk scanning. Do we have anything close to that functionality now (v6.12 or v7)?
Registrato Mon, 28 Jan 2019 18:12:06 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Steve,
That was a function of the old DACS Viewer. Today, you can of course create a seperator page that contains any content you wish to seperate on, but you still need to create a configuration and instruct it on how to seperate. There is no "cookie cutter" page anymore.
Registrato Mon, 28 Jan 2019 18:19:25 GMT di Steve Shriver Application Specialist
Phil,
Right, but you would need the Import and Barcode & Forms modules to make that work, correct?
Registrato Mon, 28 Jan 2019 18:22:26 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Si.
