Registrato Mon, 01 Oct 2018 09:53:35 GMT di Savio Karimaruthumkal
With DocuWare 7, the administrator no longer has access to the new document trays created automatically when you add a new user. Is this by design? I am pretty this was not the case with the older versions.
Savio
Registrato Mon, 01 Oct 2018 10:25:40 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Savio,
I am sure this is by design.
Registrato Wed, 10 Oct 2018 12:36:04 GMT di Savio Karimaruthumkal
Hi Phil
Thanks for getting back to me.
If you want to setup intelligent indexing for these newly created document trays, how would you go about doing that?
Savio
Registrato Wed, 10 Oct 2018 12:46:32 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Savio,
From DocuWare 6.11 onward, Intelligent Indexing is defined against a file Cabinet Store Dialog, not a Tray. Therefore, you define Intellix accordingly, and then instruct the user to attach their tray to the dialog you specify. While doing that they can also add the DocuWare administrator to the tray if required. This is a security measure.
Registrato Thu, 11 Oct 2018 11:53:56 GMT di Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Savio,
we are aware of that and with the next version the user who creates a user will get automatically access to the created tray as administrator.
Registrato Thu, 11 Oct 2018 15:54:00 GMT di Jon Weston File IT Solutions Sr Application Developer and RIM specialist
Good to hear, Tobias.  What about trays that are automatically created by a user synchronization workflow? Will the administrator automatically have access to those in the next version as well?
Registrato Wed, 24 Oct 2018 07:12:58 GMT di Savio Karimaruthumkal
Thanks Tobias.
Registrato Fri, 02 Nov 2018 14:44:29 GMT di Tobias Getz DocuWare GmbH Team Leader Product Management
Yes, this also works for user synchronization.
