Registrato Wed, 07 Feb 2018 14:53:42 GMT di Craig Heintz SE
I have 3 cabinets:  AP, AP Paid, AP Rejected
All documents start in AP and a workflow is used to approve or reject the documents.  At the end of the workflow a field is set to Paid or Rejected and an export workflow run to move the documents to another cabinet based on this.  The docs are moved to another cabinet to allow the docs to be seen and not changed by low level users.
When exporting the docs to the new cabinet, the Workflow History is not available.  Is there a way for the history to still work when exported to another cabinet on the same server?
Registrato Wed, 07 Feb 2018 15:09:49 GMT di Christopher Ure Software Support Analyst
Craig,
Unfortunately there is no way to export workflow history, as it is linked to the cabinet on which it ran.
Christopher Ure
Software Support Specialist
Support Team GREEN - Americas
