Registrato Fri, 24 Aug 2018 12:51:22 GMT di cody m3as
My company is looking to upgrade our DocuWare api code to Platform SDK 6.7. As far as any DocuWare SDK code we have on our systems, they only utilized DocuWare.Gapi assembly, which appears to be from DocuWare version 5.1.
What do we need to be cognizant of when performing this code update?
One more question: Any tradeoffs with using latest SDK version 7.0, although our server is still on 6.7?
Registrato Fri, 24 Aug 2018 13:29:13 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Cody,
DocuWare 6.7 is the last version that you will be able to use GAPI. After that you must develop using the Platform API. The Platform API uses .Net so there is significant differences in transitioning from GAPI to Platform.
The Platform files can be obtained from NUGET.
