Registrato Mon, 26 Nov 2018 22:10:01 GMT di Michael Weingand Professional Services Manager
HI Folks,
Does anyone know of a way to export a form and import it into a different customer Cloud system?
Registrato Mon, 26 Nov 2018 22:21:42 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Not possible. The problem is that a Form is tied to a File Cabinet with a specific GUID, and also fields with GUID's that importing becomes problematic.  Yes it seems easy to you, but it is not by a long shot.
Registrato Tue, 27 Nov 2018 05:55:00 GMT di Gilles Sauvagnat Altexence
Are talking about DW Forms ?
If yes I do not understand the answer from Phil
With DW Forms one can export and import a form (I thnik it was possible from 6.12).
The only limitation I am aware of are DW version must match and one has to reconfigure select lists
Am I wrong ?
Gilles
Registrato Tue, 27 Nov 2018 17:11:04 GMT di Michael Weingand Professional Services Manager
When trying to do this on two new Cloud 7 accounts I just get a simple error with no details.  No new fields in Cabinet.  Cabinet is Emplyee Cabinett on both sides. If it can be done, have you tried it?  any advice?
