Registrato Tue, 31 Jul 2018 10:59:22 GMT di Craig Heintz SE
Curious now that v7 has an app to synch AD with the Cloud does single sign on work for cloud users?
Registrato Tue, 31 Jul 2018 11:02:53 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Craig,
SSO for Cloud is in the pipeline. The first step was an AD sync for Cloud. Now that it is done, the next step is the SSO. Stay tuned.
Registrato Thu, 13 Sep 2018 16:42:55 GMT di Jeff Sanchez
Hi Phil,
So currently the user sync feature synchronizes users and groups, but the login is Docuware (application login) and passwords are not linked--Passwords for users either have to be set or the user has to use the forgot password?
Registrato Fri, 14 Sep 2018 11:26:36 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
SSO is not available yet so the first time the user tries to log in to DocuWare they should be prompted to set a password.
Registrato Wed, 15 May 2019 18:18:30 GMT di Jon Weston File IT Solutions Sr Application Developer and RIM specialist
Any updates? I thought I mighta heard that 7.1 supports SSO for a cloud system at DocuWorld but maybe I'm wrong (or dreaming).
Registrato Wed, 15 May 2019 18:20:25 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
No updates. SSO for the Cloud is not yet available, and I do not know when it will be.
Registrato Mon, 25 Nov 2019 17:17:36 GMT di Fausto Rivera Senior Systems Analyst
I was just checking in to see if SSO is available in DocuWare 7.2? SSO is pretty standard with most systems now and DocuWare is not there yet.
Thank you.
Registrato Mon, 25 Nov 2019 18:14:57 GMT di Craig Heintz SE
SSO to in a Organizations cloud set up is simple and only requires AD.
SSO to another organizations (DW Cloud) usually requires Federated Services for Active Directory.  Not something that a lot of small companies would have enabled.
Add to that some DW under the covers structure that would make it difficult and we are best to wait for a stable and working solution.
