投稿済み Sat, 16 Jun 2018 00:37:57 GMT 、投稿者 Stefan Toubia ERP Developer
I've been trying to get an embedded DocuWare viewer in my web application.  I tried using an Iframe but it seems docuware does not support Iframe?  Is that the case, or am I maybe configured wrong?
If Iframe is not an option, what are my options here?  I'm pretty much trying to set it up with a splitter, where one half of the screen is the docuware viewer and the other half is my web application.
投稿済み Mon, 18 Jun 2018 14:45:44 GMT 、投稿者 Jon Weston File IT Solutions Sr Application Developer and RIM specialist
Hi Stefan, using an iFrame is definitely supported, all you have to do is make a modification to the web.config file.  I've attached a screencap from the pdf on how to do it (we can't upload PDFs, apparently).  It works in every version after 6.5.  Let me know if you can't read the screencap and I'll type it out.
https://www.docuware.com/sites/default/files/forums-images/2018-06-18%2009_44_46-FAQ%203715%20Why%20is%20the%20Web%20Client%20not%20displayed%20in%20an%20iframe.pdf%20-%20Adobe%20Acrobat%20Re.png
投稿済み Thu, 21 Jun 2018 16:33:47 GMT 、投稿者 Stefan Toubia ERP Developer
Awesome, thank you a bunch!
