投稿済み Wed, 23 May 2018 14:23:11 GMT 、投稿者 Steve Shriver Application Specialist
Am I correct in assuming that if the Last Access field in the System Entries  (Result list->Edit Index Entries->System Entries) contains the user who has just now retrieved the document and exact time that it is at the moment he is viewing the record, that there has been no previous access to this document and that this is the very first entry? Version is 6.6.
投稿済み Tue, 05 Jun 2018 12:54:18 GMT 、投稿者 Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Steve,
you are correct in your assumption. Everytime you want to view the Last Access field (e.g. in index dialog - system entries) you have already accessed it. This means, that everytime your username will be visible.
This system field is mostly used for some kind of deletion policies. E.g. if a document is not accessed the last 10 years (together with some other filters) the document can be deleted.
Tobias
