投稿済み Thu, 03 May 2018 09:08:37 GMT 、投稿者 Kjetil Kulterud Service Owner
Is there any way I can log in to DW administration for different customers without having to reinstall the DW admin app for each customer I want to log in to?
投稿済み Thu, 03 May 2018 09:47:18 GMT 、投稿者 Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Kjetil,
Simply change the Organization name and the address in the login dialog.
投稿済み Thu, 03 May 2018 10:14:52 GMT 、投稿者 Gilles Sauvagnat Altexence Président
If you want to avoid wasting time I would sugget to go to
C:\Program Files (x86)\DocuWare\AdminTool Online
on the PC where admin tool is installed and edit the file DocuWare.Administration.exe.settings
Edit and/or add as many lines needed in section
<AuthenticationServers>
      <ConnectionSettings Name="Standard AS" Server="MyORGANIZATION.admin.docuware.cloud" Port="9000" Organization="MY ORGANIZATION Local="false" Active="true" System="Central system" />
      <ConnectionSettings Name="ALPHA" Server="docuware-online.de" Port="9000" Organization="ALPHA" Local="false" Active="true" System="Central system" />
      <ConnectionSettings Name="BETA" Server="docuware-online.de" Port="9000" Organization="BET" Local="false" Active="true" System="Central system" />
   </AuthenticationServers>
Easy to use with a simple select list from the admin tools connection screen
Hope it helps
Gilles
Altexence
投稿済み Fri, 04 May 2018 05:53:29 GMT 、投稿者 Kjetil Kulterud Service Owner
Thanks guys.
Editing the "DocuWare.Administration.exe.settings" worked like a charm :-)
