投稿済み Wed, 18 Apr 2018 19:06:10 GMT 、投稿者 Brian Burks Business Processing & Imaging Director
Is there a column in one of the tables in the DWDATA database that identifies that a document is clipped together?
投稿済み Wed, 18 Apr 2018 22:50:00 GMT 、投稿者 Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Brian,
There used to be with DocuWare 4, and I think it is still used with DocuWare 5+. I will have to look. What do you need it for - if I might ask?
投稿済み Thu, 19 Apr 2018 00:31:00 GMT 、投稿者 Josef Zayats
Brian,
the clipped (or appended) setting is stored as a bit of DWFLAGS column in the FileCabinet main database table.
Binary Position 15, decimal value 32768 (used to show as attribute "a" in old Docuware). To select database records with the bit set use the following WHERE clause:
where dwflags&32768=32768.
Hope this helps your cause.
投稿済み Fri, 20 Apr 2018 16:51:29 GMT 、投稿者 Brian Burks Business Processing & Imaging Director
We are doing an audit with one of our clients.  In their file cabinet there ar 86,518 DocIDs.  When we count up "image files" such as PDF, XLS, DOCX, etc. that adds up to 86,578.  I assumed that clipped documents would raise the image file count.  We found 37 clipped documents that all seem to be made up of 2 files.  This closes the gap down to 23.  Can you please provide a suggestion on where else to look for sources of the discrepancy?
Thank you Phil
投稿済み Fri, 20 Apr 2018 16:52:07 GMT 、投稿者 Brian Burks Business Processing & Imaging Director
Thank you Josef.  That helped a lot.
投稿済み Fri, 20 Apr 2018 16:53:47 GMT 、投稿者 Brian Burks Business Processing & Imaging Director
Error
投稿済み Fri, 20 Apr 2018 17:58:26 GMT 、投稿者 Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Brian,
First I'll need to know how you are arriving at your figures. 86,518 DocId's and 86,578 "image" files. How are you arriving at the "image" files count?
Look at the DWPAGECOUNT field. This is not a Page Count, but a Section count. Each section being a document. So what does the total of the DWPAGECOUNT field yield?
If it equals your "image" count then you are good to go.
