投稿済み Wed, 03 Apr 2019 13:22:40 GMT 、投稿者 Craig Heintz SE
Is there a way to have a document processing config send lines of an OCR'd area to a Keyword field so that each line of the OCR'd area becomes a new entry in the Keyword filed?
Example:
area to OCR:
12345678
14524134
76544567
Current output to a Keyword field if the whole area is encompassed by a text ocr zone
12345678 14524134 76544567
Desired result, three Keyword entries
12345678
14524134
76544567
投稿済み Thu, 04 Apr 2019 14:11:05 GMT 、投稿者 Craig Heintz SE
I have answered my own question.
A Keyword field can be populated by drawing multiple lines from the same single text zone and the configuring each line for a new segment of the data string.  I issue I an into that seems to be a bug with the window that allows you to set the screen info is that you cannot set the screen character and the position at the same time.  I had to set the Between Separator and the space character then close it, then reopen it and set the position to make it stick
