投稿済み Tue, 07 Aug 2018 17:34:08 GMT 、投稿者 David Jones
When using the pop up calendar to pick a date from a date field in Forms, the Year dropdown menu only displays 10 years ahead or behind the current value.  For example the default value is the current date in 2018, so the minimum selectable year in the dropdown is 2008.  If I choose 2008, then click the dropdown again, I can then choose 1998, and so on.  Is this the intended functionality?  The easier workaround is to simply type in the date instead of using the calendar, but I'm making a form intended for the public, so I want to eliminate any confusing elements if possible.
https://www.docuware.com/sites/default/files/forums-images/Date.png
投稿済み Tue, 14 Aug 2018 16:07:19 GMT 、投稿者 Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
David,
The control used here in Forms is the same Date Picker control used througout DocuWare. The range displayed is intended, although it is rather large IMHO.
