Veröffentlicht Tue, 20 Nov 2018 13:37:37 GMT von Mauricio Cruz
The Workflow server Log constantly reports the following error in the log:
Cannot switch to next tasks.
Additional information:
object_type : Org_Rt_Process_AUTOINDEX
event_type : Open
Code location - full exception trace : Waitable object already created.
   at DocuWare.Workflow.ProcessServer.WorkflowSemaphore.Lock(Guid wfSettingsGuid, WorkflowStartRestrictions restrictions)
   at DocuWare.Workflow.ProcessServer.ProcessStatusController.LockStartRestrictions()
   at DocuWare.Workflow.ProcessServer.ProcessStatusController.SetStatus(ProcessStatus status)
   at DocuWare.Workflow.ProcessServer.WorkflowHandler.AddTaskHandler(Task task)
   at DocuWare.Workflow.ProcessServer.WorkflowHandler.AddNextTaskHandlers(UIntCollection nextTaskIds)
   at DocuWare.Workflow.ProcessServer.WorkflowHandler.PutNextTasks(List`1 tasks)
Additional text :
            1) Exception Information
            Exception Type: DocuWare.Common.Exceptions.DWResultException
            MessageID: Waitable object already created.
            MessageParameters: NULL
            MachineName: AL200235323S
            CreatedDateTime: 19/11/2018 3:39:52 p. m.
            AppDomainName: DWWorkflowServer.exe
            ThreadIdentityName:
            WindowsIdentityName: AL200235323S\docuware
            DWUserLogLevel: Unknown
            TranslatedMessage: Waitable object already created.
            TargetSite: Void Lock(System.Guid, DocuWare.Workflow.Settings.WorkflowStartRestrictions)
            HResult: -2146232832
Logging Level : Error
Message Text : Cannot switch to next tasks.
Assembly : DocuWare.Workflow.ProcessServer, Version=6.9.0.0, Culture=neutral, PublicKeyToken=879da714589ba9ea
Code location - calling class : WorkflowHandler
Code location - calling method : Void PutNextTasks(System.Collections.Generic.List`1[DocuWare.Workflow.ProcessServer.TaskHandler])
Computer name : AL200235323S
Date : 2018/11/19
Time : 3:39:52 p. m.
DocuWare.Common.Logging.TimeMS : 50
Application : DWWorkflowServer
Thread ID : 195
Windows ID : AL200235323S\docuware
I have already reinstalled the workflow server, but it did not work. What can I review?
Veröffentlicht Tue, 20 Nov 2018 13:42:44 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Re-installing Workflow server will not help. There is an Autoindex configuration in the system causing problems, or the list of Tasks has an invalid entry. I suggest that you enter a Support Request so that support can look in to the problem for you.
