Veröffentlicht Tue, 18 Jun 2019 12:30:36 GMT von Romain Amoudjayan
Hello
I've made the following script in php in order to generate the url integration from an extranet.
Despite many researches, i can't find what is wrong. I always get the error message "DocuWare.Gapi.Utils.Web.DWIntegration.EX_INVALID_PASS_PHRASE".
I've tried to compare my results with the application URL creator but i never get the same url.
I'm not sure that my code is correct to hash the passphrase and split it to get the key and iv.
Any help would be very appreciated. Thank you
<?php
//script php to generate url integration for docuware
//hash passphrase with sha512 and get key and iv    ( http://help.docuware.com/en/#b64090t60297n89509 )
$passphrase = hash('sha512', 'xxxxx');
$encryption_key  = substr($passphrase,0,32);
$iv = substr($passphrase,32,16);
echo "Passphrase hash: $passphrase\n";
echo "encryption_key: $encryption_key\n";
echo "iv: $iv\n";
//create parameters string to encrypt ( http://help.docuware.com/en/#b64090t61532n89494 )
//p=D for Download
$param = '&p=D';
//Docuware login in base64
$lc = 'User=xxx\nPwd=xxx';
$lc = convertToUrlTokenFormat(base64_encode($lc));
$param = $param . '&lc=' . $lc;
//fc=guid of the concerned file cabinet
$param = $param . '&fc=xxx';
//request in base64
$q = '[N__DOCUMENT]=xxx';
$q = convertToUrlTokenFormat(base64_encode($q));
$param = $param . '&q=' . $q ;
//download type
$param = $param . '&dt=Download';
echo "Before encryption: $param\n";
// Encrypt $param using aes-256-cbc cipher with the given encryption key and iv
// The 0 gives us the default options, but can be changed to OPENSSL_RAW_param or OPENSSL_ZERO_PADDING
$encrypted = openssl_encrypt($param, 'aes-256-cbc', $encryption_key, 0, $iv);
echo "Encrypted: $encrypted\n";
//Encrypted paramters string encrypted again in base64 (see https://support.docuware.com/fr-fr/knowledgebase/article/KBA-35664 )
$encryptedbase64 = convertToUrlTokenFormat(base64_encode($encrypted));
echo "EncryptedBase64: $encryptedbase64\n\n";
$url = 'http://xxx/DocuWare/Platform/WebClient/1/Integration?&ep=' . $encryptedbase64;
echo "URL: $url\n";
function convertToUrlTokenFormat($val)
    $padding = substr_count($val, '=');
    $val = str_replace('=', '', $val);
    $val .= $padding;
    $val = str_replace('+', '-', str_replace('/', '_', $val));
    return $val;
Veröffentlicht Tue, 18 Jun 2019 12:31:36 GMT von Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Romain Amoudjayan! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-69877-N4K5V for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
