Veröffentlicht Thu, 12 Mar 2020 06:27:58 GMT von Mayra Rossi
Good morning,
I have a problem with a loop within a workflow.
I created a loop to add all the partial amounts contained in a table field. When there are too many rows (I think more than 10), the woorkflow is unpupblished.
How can I change this setting in Docuware 7.2?
Thank you
Veröffentlicht Thu, 12 Mar 2020 06:28:59 GMT von Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Mayra Rossi! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-122658-S8P0C for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Veröffentlicht Mon, 23 Mar 2020 06:53:05 GMT von Franziska Klein Specialist Software Support Team GREEN EMEA
Hello Mayra,
in the following 2 files you can adapt the settings for how many repeats are identified as endless loop:
DocuWare.BackgroundProcessService.LongLiving.GenericProcess.x86.exe.config
DocuWare.BackgroundProcessService.LongLiving.GenericProcess.exe.config
Both files can be found here: C:\Program Files\DocuWare\Background Process\Service\
You can change the value for MaximumActivityEnters.
Do not set it to high.
This option is working for On-Premises systems.
Veröffentlicht Tue, 09 Mar 2021 18:08:12 GMT von Jon Weston File IT Solutions Sr Application Developer and RIM specialist
You'll need to restart the background process service once you've made these changes.
Veröffentlicht Thu, 20 May 2021 12:10:39 GMT von Fabian Kall - left 01.22
KBA 35837 states, that the value for SystemActivityLoopTreshold should be changed in DocuWare.Bpw.Service.exe.config in order to achieve this.
What is the difference? Is it due to different DocuWare Versions?
