Veröffentlicht Tue, 12 Feb 2019 13:34:12 GMT von Carlos Angel Rocha
Good day
On this occasion we require your support in order to guarantee a newly created NTLM domain authentication,
At this moment the users enter automatically with the name of the server http: // docuware / DocuWare but by organization we decided to create a domain sgdabog.edu.co which does not allow the same automatic entry because the chrome browser asks for a user and password
In what place would we have to make the adjustment for this configuration?
Thank you!
https://www.docuware.com/sites/default/files/forums-images/captura.jpg
Veröffentlicht Tue, 12 Feb 2019 16:53:58 GMT von Simon H. Hellmann Wedderhoff IT GmbH Systemadministrator
Hello Carlos,
this is a well-known issue. To get Windows Login (NTLM) working again, you need to do some additional client-side work. If needed, the following settings can also be pushed via GPO.
For Firefox, follow this FAQ: https://faq.docuware.com/en-us/knowledgebase/article/KBA-35976
For Internet Explorer / Edge / Chrome:
1. Open up Internet Explorer
2. Click the little cog wheel in the top right corner, then select "Internet Options"
3. On Tab "Security", select the "Local intranet"-Zone
4. Click "Sites", and in the new window, click "Advanced"
5. Add all the URLs which your DocuWare server uses here:
Example: http://docuware/ and http://docuware.sgdabog.edu.co/
After this, restart all the browsers and you should be good to go.
