Veröffentlicht Mon, 28 May 2018 09:29:28 GMT von Kjetil Kulterud Service Owner
Is it possible for DocuWare to automatically redact given areas on a document?
Veröffentlicht Mon, 28 May 2018 21:29:42 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
DocuWare does not do redaction. Sure you can add overlays that appear to be redaction, but those overlays can be turned on or off by the user.
To truly redact a document, you must add an overlay that obscures the area in question, and then merge the layer with the document to make the layer a permanent part of the document. Since this will only be possible with PDF type documents this may or may not be a solution.
Veröffentlicht Tue, 29 May 2018 09:25:01 GMT von Kjetil Kulterud Service Owner
Ok. Thanks!
But is it possible to do this automatically somehow?
Veröffentlicht Tue, 29 May 2018 16:52:15 GMT von Josef Zayats
Kjetil,
a simple REST API program can be written that when executed would place an annotation (in your case a filled rectangle) in a predetermined position(s) and page(s)  on  some documents (selected by aspecified search criteria). You also can optionally merge the annotaion on documents (providing they are PDFs) by the program so the redaction is permanent or leave them as layers.
