Veröffentlicht Thu, 26 Apr 2018 11:20:04 GMT von Kjetil Kulterud Service Owner
A customer of ours have several document they want to delete 12 months after the "end date" is set in one of the metadata fields.
How could I solve this with the Deletion Policy module?
Thanks!
Veröffentlicht Thu, 26 Apr 2018 11:28:10 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
With DocuWare 6.12:
End Date Is Before the Past 12 Months
https://www.docuware.com/sites/default/files/forums-images/DeletionP.png
Veröffentlicht Thu, 26 Apr 2018 16:30:56 GMT von Kjetil Kulterud Service Owner
Veröffentlicht Tue, 26 Jun 2018 18:16:47 GMT von Salvador Diaz Pre Venta
I created a new Deletion Policy, but when i execute the proccess, give me back the next message: "Server is not responding"
https://www.docuware.com/sites/default/files/forums-images/deletion%20policy.png
Veröffentlicht Mon, 02 Jul 2018 05:18:10 GMT von Simon H. Hellmann Wedderhoff IT GmbH Systemadministrator
Hello Salvador,
have you tried restarting the DocuWare WorkflowEngine and BackgroundProcess Processes?
Veröffentlicht Mon, 02 Jul 2018 17:54:35 GMT von Salvador Diaz Pre Venta
Hi Kjetil Kulterud, i re started before the process you asked me, and it doesn´t make difference.
Thanks.
Veröffentlicht Wed, 29 Aug 2018 17:10:06 GMT von Dylan Brunette
Hello Phil,
I want to delete all of the documents older than 2 months old based on the date of the report (metadata) and not the date of document storage. Field is called Date. Would I then do "Date Before the Past 2 Months"? Just want to be sure I understand the logic in the statement.
Thank you,
-Dylan
Veröffentlicht Wed, 29 Aug 2018 17:19:29 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Dylan,
Yes to delete all documents older than 2 months would be "Before past 2 months". You can use any Date type field in your file cabinet to test against.
