Veröffentlicht Wed, 25 Nov 2020 15:21:09 GMT von Lee Wiltshire Technical Director
I have a Recruitment Company customer that needs to send a timesheet to their customers every month with a current list of the people that they have employed that month and the employees change every month. I am trying to recreate it in Docuware Forms using merge forms and Workflow to populate the form but I can't see how I can get a dynamic visible list of employees onto the Form before it is then sent to the customer. I understand how to use form fields to do something similar but  the closest I can get is that it populates the list after the customer has filled the form in and the workflow then allows it to be populated with employees names but that won't work in this scenario. Has anyone tried this type of action before?
Veröffentlicht Wed, 25 Nov 2020 15:22:09 GMT von Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Lee Wiltshire! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-139590-S1W8X for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Veröffentlicht Wed, 20 Sep 2023 16:57:07 GMT von Jonathan Smith Business Applications Specialist
Any updates on the original question? I have a similar use case where this functionality would be valuable.
Thanks!
Veröffentlicht Thu, 21 Sep 2023 07:52:51 GMT von Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Jonathan,
for a more or less similar use case, I could not find a solution just using DocuWare Modules, so I developed a tool which grabs data from a DocuWare Table field and fills an excel template with that data.
Problem in Forms is that table fields are still not yet supported and pre-populating fields is not really possible, you can only use select lists. Everything else has to be done in Workflow.
