Veröffentlicht Mon, 08 Jul 2019 09:45:05 GMT von Christophe Mathieu Ricoh Luxembourg PSF sàrl Document Solutions Specialist
We have a Store Dialog with an index configured with Predefined Entry (e.g. Date using Current Date). This value is correctly used when storing documents one by one or when selecting multiple documents using the "Store" function.
But when using "Store Automatically" function in Web Client, the Predefined Entry is not used (left blank). Is there a way to configure this function to work like the "Store" function ?
Tested in DW Cloud, I assume the behavior is the same on premise.
Christophe.
Veröffentlicht Mon, 08 Jul 2019 09:46:05 GMT von Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Christophe Mathieu! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-71183-B6R9R for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
Veröffentlicht Fri, 26 Jul 2019 11:22:30 GMT von Pascal Tham DocuWare Europe GmbH Team Leader Software Support Team ORANGE EMEA
Hello Christophe,
This is behavior by design. The predefined values will only be used, if the respective field is either "Read only" or "Not visible".
As a workaround you can create another Store Dialog with the Date field as read only and make this dialog default.
With best regards
Pascal Tham
Software Support Specialist Team RED EMEA
Veröffentlicht Mon, 24 Nov 2025 10:18:15 GMT von Gerd Hübner Leitung Softwareentwickler
Another point is, that "Store Automatically" always uses the standard store dialog. A fact, that is nowhere documented and caused a lot of disturbance especially when there are obligatory index fields or index fields with a prevalue assigned via the store dialog.
