Hey,
I believe you can use JSONPath filters to make a selection from the returned JSON.
Filters
Filters are logical expressions used to filter arrays. An example of a JSONPath expression with a filter is
$.store.book[?(@.price < 10)]
where @
represents the current array item or object being processed. Filters can also use $
to refer to the properties outside of the current object:
$.store.book[?(@.price < $.expensive)]
An expression that specifies just a property name, such as [?(@.isbn)]
, matches all items that have this property, regardless of the value.
For your example try $.Item[?(@.Name =~ /^DW_.*/)].Name, I tested in the new workflow designer and it appeared to work. You could also just store all of the items in a keyword field and then use an expression to get the one you want.
Regards,
Jacob Eaton
