Posted Wed, 28 Oct 2020 09:35:18 GMT by Léo BIANCO
I've been trying different ways to solve my problem but nothing seems to work !
Here is my problem :
I'm trying to edit a file using the Section.PutToContentRelationForSectionAsync() method. Everything works fine and I'm actually able to change the content of my document by giving it a "Stream" object.
My issue is that the name of the file changes by a random string like "003aE6-....". Thing is I want it to stay the same name as it was when I uploaded the document. It does not cause any problem until you try to modify manually the file ! If you right click and "modify", the name of the file will be the random string ! Same if you export it to work locally on you computer !
Is there anyone who knows how to deal with this OriginalFileName issue when modifying the content of a document?
Thank you !
Best regards,
L.
Posted Wed, 28 Oct 2020 09:36:18 GMT by Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Léo BIANCO! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-137663-W5J1G for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
