Posted Tue, 01 May 2018 20:28:10 GMT by Robert Oswald CIO
I've created two Document Relationships - one for use by HR and one for everyone else. I've linked these to specfic result and list dialogues. My problem is that I can't seem to restrict task lists in the same way. Consequently from a task list, both document relationships are selectable. Is there any way to fix this?
Thanks for any suggestions.
Posted Wed, 02 May 2018 00:27:48 GMT by Josef Zayats
Robert, though Docuware 6.12 is the very first version where you can restrict which result dialogs and Lists the document relations are available, it seems to be working as expected for me. I suppose, the only trick - to avoid confusions -  is to disable any document relations for all result dialogs you use to display any document relations. This way you can pretty much control whch relations available on which result/lists, and consecutively to which roles/users.
