Publié Tue, 05 Jan 2016 15:23:58 GMT par James Auman North Carolina Rate Bureau IT Systems Engineer
I'm moving Fortis to a new server (just the application, the database is on a separate server and staying put).  The move instructions tell me that i first need to install Fortis from scratch on the new server before i move anything over from the old server.  Is that right? If so, when i get to the step that asks for yout to "select your configuration folder", what should i do?  Since it's a new server, there isn't a configuration folder present just yet.  Should i navigate to the configuration folder on my old server? Should i copy the configuration folder from the old server to the new one and then point the install to the copy?  Do i need to ask DocuWare to do something since it's a new server?   NOTE: I have attached a copy of the prompt that i'm stuck at if you want to take a look.
https://www.docuware.com/sites/default/files/forums-images/fortis%20configuration%20folder.png
Publié Tue, 05 Jan 2016 15:33:29 GMT par Tyler Behuniak Professional Services Assistant
Jim,
You will need new install configs in order to install a new copy of Fortis. Once you recieve the new install configs, you will point them to this folder. In order to get these configs please contact your partner, Ricoh. If you need any additional assitance your partner should be available to help.
Publié Tue, 05 Jan 2016 15:48:15 GMT par James Auman North Carolina Rate Bureau IT Systems Engineer
Will geting new configuration files break our old installation?  We are just doing a test run of a move at the moment.  It seems like last time we moved, i just copied my configuration folder over and used that during the new install.  Did i remember that correctly?
Publié Tue, 05 Jan 2016 15:57:29 GMT par Tyler Behuniak Professional Services Assistant
This is not a supported way of installing Fortis. The new install configs will not break your exisitng install however if it is a test, you can just install the demo.
Publié Tue, 05 Jan 2016 16:09:54 GMT par James Auman North Carolina Rate Bureau IT Systems Engineer
Thanks Tyler.  One last question.  If we install the demo, but then want to register it later for production use, can we point Fortis to the new configuration folder after the install is completed?  or will we need to start the install over again and provide the new configuration folder at the beginning?
Publié Tue, 05 Jan 2016 16:14:45 GMT par Tyler Behuniak Professional Services Assistant
You would need to install Fortis again as the demo may not install some of the options that you are licensed for.
Publié Tue, 05 Jan 2016 16:23:40 GMT par James Auman North Carolina Rate Bureau IT Systems Engineer
Thanks Tyler!!
Publié Tue, 05 Jan 2016 17:38:39 GMT par James Auman North Carolina Rate Bureau IT Systems Engineer
Ricoh support is telling me they don't provide configuration folders.  The support tech is telling me that they aren't setup to do that.  They are telling me i simply need to backup the old server and restore it to the new server.  Does that make sense?  I told them what you told me in the above comments and they said they didn't understand why you would tell me this.
Then they sent me the Fortis Move instructions which i already had.  I told them that i just need a configuration folder.  Now they want to send out a professional services rep to our location. I just need a folder.  I think they don't quite understand what i'm trying to do.   Is there anyway DocuWare can either send me this folder directory, or contact Ricoh and help them understand what I'm asking for?  FWIW, i've done this once before when we moved from Windows 2003 to 2008R2.  I can't understand why they are struggling with this request.
Publié Tue, 05 Jan 2016 19:16:52 GMT par Tyler Behuniak Professional Services Assistant
Jim,
I will follow up with you via email.
