Registrato Tue, 05 Jan 2016 20:50:21 GMT di James Auman North Carolina Rate Bureau IT Systems Engineer
I have a new server running Fortis.  When i attempt to install the client on a desktop, i get the following error
Error reading D:\Imaging\FortisDT\SYSDATA\fmconfig.dat
The installer closes at that point.  I am a domain administrator so i have local admin rights to the Fortis server and the desktop.  That makes me think it isn't a permissions issue.
https://www.docuware.com/sites/default/files/forums-images/fortis%20workstation.png
Registrato Tue, 05 Jan 2016 21:03:20 GMT di Patrick Seresin Product Quality Support Analyst
Jim,
See the following article:
https://www.docuware.com/support_faq/?solution_id=3868
Registrato Wed, 06 Jan 2016 13:28:52 GMT di James Auman North Carolina Rate Bureau IT Systems Engineer
It was the base.ini file.  I had the actual path, not the UNC path.
