Registrato Sat, 30 Jan 2021 07:49:22 GMT di Tom Depiera
Im trying to build an application that will make updates to dialog fields and properties but I'm having some issues getting the properties to update in my code.
for instance, if I have a list of fields in my application, I'm able to select each of them and look at certain field properties, such as whether the field is ReadOnly or Visible in the dialog.
However, it doesnt seem to work when I try to set the values of those fields by doing something like this
selectedField.Visible = true;
selectedField.ReadOnly = true;
Is this something that is possible with the SDK?
Registrato Sat, 06 Feb 2021 07:49:22 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Tom Depiera! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-143616-B2F6F for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
