Registrato Wed, 20 Jun 2018 17:03:09 GMT di Frank Camarena System Analyst
Morning.
In the past I sent a request as a Admin to an user to validate a document for a demo purposes.
Now logged as a Admin I trying to delete the request but I can`t, even if I try to access to the request. An error says: "Do do not have enough file cabinet rights...". Mencioned about to contact a WorkFlow Controller but I don`t know how to acces.
A screencap is attached.
What I should do to delete this request?
Thanks in advance.
https://www.docuware.com/sites/default/files/forums-images/Dw%20error%20Request.JPG
Registrato Thu, 21 Jun 2018 07:16:17 GMT di Benoit Vassart ASC
Dear Erick,
Please select the option: All Tasks: You should see the workflow task ID.
Connect to the Workflow designer and stop the workflow task ID.
Kind Regards
Registrato Thu, 21 Jun 2018 07:16:20 GMT di Benoit Vassart ASC
Dear Erick,
Kind Regards
Registrato Wed, 10 Oct 2018 21:34:04 GMT di Willian Ortiz Tics
Al exportar solicito muestra el siguiente error.
  1. El trabajo ha fallado. El acceso a la ruta '\\ d2mxkxm2 \ Request \ DocuWareRequest \ 317ad36e-d237-4ef0-899a-164211cd8479 \ 2018101022391721713' está denegado.
https://www.docuware.com/sites/default/files/forums-images/Sin%20t%C3%ADtulo.png
