Registrato Fri, 21 Jun 2019 18:16:00 GMT di Scott Roberts Xerox Systems Admin
Has anyone ever used auto index to export metadata to an external data source?
Registrato Fri, 28 Jun 2019 11:24:45 GMT di Markus Zoichter
We are using autoindex to sync index entrys from a docuware cloud system to a local database.
What exactly do you need to know?
Registrato Fri, 28 Jun 2019 12:25:59 GMT di Scott Roberts Xerox Systems Admin
I was unsure of the auto index config but I figured it out using the write back tab and the doc id as a match field. This thread can be closed.
