Registrato Tue, 19 Jul 2022 16:14:34 GMT di Daryl Foxhoven Sr. Systems Engineer
I have a customer that wants to setup a condition so that any Invoice scanned is less than 4 pages, it goes to a clerk for review (as their AR invoices should be a minimum of 4 pages).  I initially thought I could at least capture the system field for DWTOTALPAGES in Workflow designer, but appears it's not available which is mind boggling to me why system fields would not be available.  I then though perhaps I could capture it via AutoIndex job....again...I can use DWTOTALPAGES as a match condition, but I cannot use it to populate an index field.  Seems very antiquated that it's not available....does anyone have a workaround or know how you might be able to accomplish this?
Thanks!
Registrato Tue, 19 Jul 2022 17:18:18 GMT di Daryl Foxhoven Sr. Systems Engineer
Figured it out
