Registrato Wed, 08 May 2019 16:04:03 GMT di Sabino Civita
I created an index profile that allows to view, for example, three kind of documents: customer invoice, supplier invoice and packing list (this is just an example).
All these documents belong to a dossier (dossier can have many kind of documents). I need to do three different search dialogs. All are the same. But on one I want to search only first kind of document (and view only this), on the second one only second kind of document and so on.
I know that I can create three different selection list for the document type and assign this to the right search dialogs...but If I use the search field Dossier, the result is however all documents, even if I'm using search dialog window related, for example, to the first kind of document....
Yes, maybe explanation it's not so clear. but I hope you understood the question and maybe someone has a solution...
Registrato Wed, 08 May 2019 16:05:03 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Sabino Civita! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-67202-F3W0V for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
