Registrato Mon, 04 Oct 2021 22:46:13 GMT di Carlos Alberto Valera Cueto Solution Specialist
En un Workflow al habilitar la casilla de seleccion de enviar documento pdf adjunto con la notificacion de la actividad, al ejecutar el flujo muestra el error siguiente en el historial del flujo.
Se hizo la prueba enviando la notificacion sin el adjunto y esta se envia correctamente, la cuenta de correo electronico no tienen ninguna restriccion.
Adjunto la pantalla
-----------------------------------------------------------English-----
In a Workflow to the Enable checkbox to send pdf document attached to the notice of the activity, the run flow shows the following error in the history of the flow.  The test was sending the notification without the attachment and this is sent successfully, the email account have no restrictions.
Registrato Mon, 11 Oct 2021 22:46:13 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Carlos Alberto Valera Cueto! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-161560-P7N8V for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
