投稿済み Thu, 07 Jan 2016 20:03:46 GMT 、投稿者 James Auman North Carolina Rate Bureau IT Systems Engineer
We are currently at Fortis 6.8.  According to the White Paper "From Fortis to DocuWare", the last releases of Fortis and FortisBlue are scheduled for September, 2017.  Does that mean we can expect to see versions of Fortis beyond 6.8?  My initial understanding was that Fortis 6.8 was the last version.  Is there another release being planned?  If so, can you give us a timetable?
投稿済み Thu, 07 Jan 2016 21:36:08 GMT 、投稿者 Chad Folts Professional Services Engineer
Jim,
Fortis and FortisBlue version 6.9 will be released Q1 of this year.
投稿済み Fri, 08 Jan 2016 14:23:38 GMT 、投稿者 James Auman North Carolina Rate Bureau IT Systems Engineer
Great! Does staying up to date on Fortis releases make the transition to DocuWare easier when the time comes?  In other words, is migrating from Fortis 6.9 to DocuWare 6.9 easier than Fortis 6.8 to DocuWare 6.8?  And if that's the case, will Fortis 6.10 be even easier?  I'm thinking that the longer we wait to migrate to DocuWare, the easier it may be for us (DocuWare will continue to improve and refine the migration process).
投稿済み Fri, 08 Jan 2016 15:10:36 GMT 、投稿者 Chad Folts Professional Services Engineer
Yes - Staying up to date with the Fortis releases will make the transition to DocuWare much smoother.
