投稿済み Mon, 01 Nov 2021 14:15:42 GMT 、投稿者 Ben Greenwood Keeley Travis DocuWare System Consultant
Hi all
Anyone else having trouble signing into the DocuWare Academy?
I can sign into support, the main DocuWare site and the Partner Portal as normal, but when trying to access the Academy I get redirected to a Microsoft log in (which tells me I don't exist within DocuWare GmbH) and not the usual DocuWare ID sign in - this despite being logged in already! Same happens if I am logged out too.
HELP!
投稿済み Tue, 02 Nov 2021 13:09:27 GMT 、投稿者 Peter Otto Process Automation Specialist
I have the same problem
投稿済み Tue, 02 Nov 2021 13:13:05 GMT 、投稿者 Ben Greenwood Keeley Travis DocuWare System Consultant
Hi Peter
Try using an incognito window and going to JUST academy.docuware.com - then go to the Home page and you SHOULD see Log In with Docuware ID, instead of the Microsoft log in.
That's how I EVENTUALLY got in, but it is not a long term solution...
