投稿済み Tue, 18 May 2021 17:05:48 GMT 、投稿者 David Haythorn Senior Engineer
Customer has enabled ssl on the DocuWare v7.3 web server. The web connections in DocuWare Administration have been edited to reflect https:.
I get the following errors when accessing Document Processing in Configurations:
1) Could not establish trust relationship for the SSL/TLS secure channel with authority 'Server host name' if the LocalWebServices value in the dwmachine.config is set to http.
2) The provided URL scheme 'https' is invalid: expected 'http'. Parameter name: via if the LocalWebServices value in the dwmachine.config is set to https.
Other aspects of DocuWare are working as expected using https in the url.
投稿済み Tue, 25 May 2021 17:05:48 GMT 、投稿者 Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear David Haythorn! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-150913-T1V6C for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
