投稿済み Thu, 10 Feb 2022 08:35:47 GMT 、投稿者 Winston Ong Senior Digital Services Consultant
Hi there,
Is it possible to return the result entries count from a List? We would like to use it for a condition in the workflow activity.
Please refer to the attached screenshot. In this example, we would like to grab the no. of entries, which is value "17".
Thank you.
投稿済み Thu, 10 Feb 2022 08:41:04 GMT 、投稿者 Winston Ong Senior Digital Services Consultant
We are on DocuWare Cloud 7.5
投稿済み Fri, 11 Feb 2022 12:30:47 GMT 、投稿者 Fabian Kall
A bit of a workaround, but:<br> <br> you could use a global variable of type keyword, then fill that in a data assignment with some unique value of the documents in the list by using the same query logic that the list uses, for instance, fill it with the DocIDs.<br> Then use the count property of that keyword variable to get the number of entries.<br> <br> However, this will be a moment-in-time count, so if you need the count in multiple stages of your workflow, you may need to do the same thing each time, and you will need to update workflow whenever you change the query logic in the list.<br> &nbsp;
